Unfortunately we are virtual today and tomorrow due to water pipes bursting over our holiday break. Are there any VEX 123 activities that can be assigned virtually through Google Classroom?
@Tina_Dietrich You should have access to the VEXcode VR 123 playground that the students can do virtually - it requires a premium account (which you have).
The VR 123 Playspace is a great option - here are some articles that can help you get started:
- Using the Playground Window in the 123 Playspace will tell you about the features/buttons on this playground and how to use them.
- Choosing an Activity in the 123 Playspace will tell you about the different playground setups that you can choose. All of the Activities are based off of existing 123 Activities (so you could essentially complete the same activity with both a virtual and physical robot).
Additionally, you could use the 123 Printables to have students plan their projects to complete and Activity at home, then run their projects when they return to school to iterate on them. Hope this helps @Tina_Dietrich! And good luck with the pipe situation!
