Any hints or tips for helping students with the Arm Install Program, we have alot of failed joints and there are no directions for fixing them on the build pdf, where can we find these? Thanks
Hi @Marissa_Brown! Great question ![]()
I have a couple of resource suggestions:
The first would be the VEX V5 Workcell Educator Certification Course. This will walk you through all of the STEM Labs and any supporting material that you would need to be successful. It’s also all video based.
The VEX Library. There are tons of articles here for troubleshooting, including:
There are also some videos in the Video Library.
Let me know if this helps ![]()
@Lauren_Harter We cannot get the joints to pass. Is there a trick to joint one? Something you can suggest? We have followed all the directions. Thanks
Hi @Marissa_Brown! I’m sorry to hear the joint is still not passing.
I responded to you in this other thread ![]()
