In addition to the EXP STEM Labs, EXP Activities are also available. Check out all of the different activities that you can use to get up and running with EXP right away!
You can also get up and running with either the EXP BaseBot or Clawbot using the Build Instructions found at builds.vex.com.
This is our first wave of EXP Activities, keep an eye out for more! The first wave was designed to complement our first EXP STEM Lab Units. They can be used to reteach coding or engineering concepts, used as extension activities, or for student-driven independent exploration.
- See our EXP Cumulative Pacing Guide to see how these Activities can be used in conjunction with STEM Lab Units, and even connect to VEXcode VR Activities to support asynchronous and hybrid teaching.
