Are you doing a lesson on Gear Ratios?
Check out my Gear and Gear Ratio video.
There is also a Google Presentation for the video if you prefer a different format. Don’t forget to File> make a copy, if you want to customize the presentation
I also have an older video series on gear ratios:
Certainly do not forget the Knowledge Base articles:
Also check out the STEM labs:
