Modifications of VEX IQ (2nd generation) activities for use with the VEX IQ (1st generation) kits
It was so exciting to see @Lauren_Harter’s post about the new VEX IQ STEM labs and activities for the 2nd generation kits. A number of the VEX IQ activities will need no modifications in order to be used with the VEX IQ 1st generation kits. With the exception that the colors of the parts in the graphics may be different, it does not matter which kit you use with the following activities:
The activity, Can You Name That Part (A game to identify VEX IQ parts), Requires only the substitution of the VEX IQ 1st generation parts poster (.pdf).
The activity, Spin Your Wheels (Can you calculate how fast your wheels are spinning using measurements from a VEXcode IQ project), can be used with any one of the VEX IQ builds which have a wheel-base drivetrain. You only need to make sure you are using a drive motor port when you are configuring the motor for the VEXcode IQ project.
Some of the other activities you can substitute the 1st generation Standard Drive Base for the 2nd generation BaseBot. Just ensure the motor ports are correct when you configure your VEXcode IQ project. These activities include:
The 1st generation Clawbot can be used in the activity, Forward, Lift, Reverse (what direction is faster when moving an object).
More activities will be added and they will also be capable of being modified to be used with the VEX IQ 1st generation kits.
@David_Kelly This is a wonderful, wonderful post. Thank you very much. @Bonnie_Sikorski I think you will find a lot of ideas here.
Really useful for when Gen 2 landing the UK, thank you.
Thank you @Michael_Nelson! Welcome to the community!
Amazing! Thank you @David_Kelly!
