I have 9clawbot) robots not working correctly. Specifically the claw and the arm. I have done some trouble shooting with the robots. I have made sure the controller is working properly by checking in the device mode on the brain, I have changed the cord, motor, and readjusted the cables. Obviously checked if in the right ports. I do notice that the light is not green in the port. At one point the robot did work correctly.
Right now I am working on trading ports on the brain to correct the problem.
Ok, I’ve had the same problem on various bots. What I’m finding mostly is the smart cables are bad. I did have a bad motor.
