VEXcode V5 has a code viewer built in so that you and your students can make connections between the block-based coding they are already familiar with and the new text-based coding they are learning.
Have you used the Code Viewer in VEXcode V5 to facilitate the transition from block-based coding to coding with text in your classroom? What other methods have you tried to make that transition with your students?
