VEX 123 field pdf
I took the pdf file of the VEX 123 field, and printed it out on a poster maker. The measurements do not perfectly match up to the true size of a 123 board. From the measurement of the inside of the squares, it’s 1 7/8" short. So the robot doesn’t exactly move the correct distance (number of squares). I had our tech department look at it, and they couldn’t figure out how to make it the correct size. Anyone else have that problem, or have any suggestions?
@Aimee_DeFoe @AudraSelkowitz @Desiree_White-Price
I think you likely have a scaling option such as fit to page set, or the paper size is set wrong on the printer.
I just printed one here and the scale was correct.
@Chris_Calver That was it! My setting was fit to page and once I changed it to 100% it worked perfect. Thanks!
@Chris_Calver @Tina_Dietrich Thanks so much for tag teaming this. My students enjoy using this. It is also a great backup when you have a hectic day and you forget to get the boards ready for the day.
