VEX AIR Flight Certification Course is now live!
Get ready to take flight with the VEX AIR Flight Educator Certification Course! This Intro Course is designed to help you prepare to teach the VEX AIR Virtual Flight and Controller Flight Courses with comfort and confidence.
You can access the certification course in the Intro Courses section of PD+. Throughout this self-paced course, you will be introduced to VEX AIR while covering key concepts from the Virtual Flight and Controller Flight courses. You will learn about things like:
  • Getting your VEX AIR Kit ready for flight.
  • The VEX AIR Flight Simulator as a safe, virtual environment to learn to fly.
  • How the VEX AIR Drone is controlled with the VEX AIR Drone Controller and VEXcode AIR.
  • How interchangeable modules allow the drone to interact with the environment.
  • The tools, resources, and supports designed to help you implement VEX AIR effectively and confidently in your environment.
  • and more!
Once you complete the certification course, you will not only be ready to teach with VEX AIR, and also have full access to post and respond in the AIR Section of the PD+ Community! Respond here to let us know that you’ve gotten certified, and share you experiences, questions, and flight stories with the AIR Community first-hand.
Your VEX AIR Certificate and badge can be accessed from your PD+ Dashboard. Select the View all Certificates button below your Profile information on the right hand side.
