I am trying to connect the brain of our EXP to my chromebook running VEX Code V5 and the brain is not showing up. Any troubleshooting ideas out there? Has anyone else been successful using a chromebook to run VEX Code V5 especially with the EXP robots?
Hi @Brett_Lange!
The reason your EXP brain is not registering is because you are running VEXcode V5. Try using this link which is VEXcode EXP. This should remediate the problem you are experiencing. ![]()
This article is also very helpful in regards to pairing the two.
For further troubleshooting techniques, please see this article.
Please let me know if this solves your problem, or if there is anything else I can assist with!
