Hour of Code 2022 is fast approaching, and we are hard at work putting the finishing touches on a host of fun and exciting activities for the big day! This year, we are offering coding activities across the VEX Continuum, including a Castle Crasher activity for every platform from 123 to EXP! Here is a sneak preview of what is coming up!
For VEX 123:
- Castle Crasher 123: (Coder) Use the Art Ring to add a castle crashing tool to your 123 Robot and code it to Crash all the castles on the Field into the Crash Zone without falling off!
- Squirrel Away! (Touch) Turn your 123 Robot into a squirrel using the Art Ring, and code it to gather as many acorns as possible and hide them in a tree for the winter!
For VEX GO:
- Castle Crasher GO: Code the Code Base Robot to clear as many castles as possible from the Field in two minutes without falling off. Modify your robot to more successfully crash the Castles!
- Robots on Parade: Turn your robot into a Computer Science themed parade float, and code it to travel a parade route with other Robots!
For VEX IQ:
- Castle Crasher IQ: Compete to see which team can clear all the castles off the Field the fastest! Each team must code their robot to compete completely autonomously.
- Maze Race: Compete to solve a maze as quickly as possible by Coding the Speed Build and using the Bumper Switch. The fastest time wins!
For VEX EXP:
Castle Crasher EXP: Compete to see which team can clear all the castles off the Field the fastest! Each team must code their robot to compete completely autonomously.
Pizza Delivery: Code the Speed Build to successfully deliver pizzas to the correct houses in this tasty challenge!
For VEXcode VR:
Coral Reef Cleanup: Code the VR Ocean Cleaning Robot to clean as much trash as possible off the Mangrove Reef before the solar-powered batteries on your robot run down!
VEX GO Competition: Mars Math Expedition: Code your Hero Robot to collect and deliver samples from craters to the Lab on Mars!
Castle Crasher + : Write code for the VR Robot to clear as much of the castle as quickly as possible, but don’t fall into the water!
VIQC Virtual Skills: Pitching In: Get as many points as you can in one minute by pitching balls into the low and high goals in the Pitching In Competition.
Rover Rescue: Code your Robot Rover to stay alive for as long as possible by collecting fuel cells and fighting enemies on Planet Debug.
VRC Spin Up: Code your robot to get as many points as possible by shooting discs into Low and High Goals, and spinning the Rollers!
@Anna_Blake Hopefully this is helpful to you in your planning!
