VEXcode EXP version 4.60.1 is now available. It can be downloaded here: VEXcode Install EXP - VEX Robotics
The VEX Library’s New Features in VEXcode EXP 4.60 shows off all the new features in this release.
- Redesigned Python and C++ toolboxes with collapsible sections, syntax highlighting, and category icons for easier text coding.
- Reorganized Blocks toolbox with clearer categories, subcategories, and updated groupings, plus active category highlighting so blocks are easier to find.
- Updated block color themes for better readability and accessibility.
- Added string blocks for working with text in Blocks projects
- Split the Looks category into separate Console and Screen sections so print commands and screen controls are easier to find.
- Combined math and comparison functions into a single, streamlined operator block.
- Improved download speed for Python and Blocks projects.
- Refreshed app icons with brighter, higher-contrast colors for better visibility.
- Brain Information now shows Console Serial Port status, and Print Console displays an overlay when the port isn’t connected.
- Added the ability to save and copy images from the AI Vision sensor video feed.
- Simplified generated code when printing variables and Boolean values.
- Added support for the V5RC Push Back AI classification model on the AI Vision sensor.
- Android minimum system requirement is Android 9.
- FireOS minimum system requirement is FireOS 7.0.
- Chromebook minimum system requirement is ChromeOS 100.
- iPadOS minimum system requirement is iPadOS 16.
