I am using the web-based version of VEXcode EXP because that is probably what my students will be using. I am working through the certification course and am running into an issue with the Drivetrain code (pasted below). The robot wheels continue to turn after the 90 degree turn. I even tried putting a “stop driving” block at the end and it still turns. I also used example project codes and its the same.
