VEXcode GO 4.61 release
VEXcode GO version 4.61 is now available. You can find the changes listed below.
  • Removed translations from math operator block dropdown options.
  • Added option to expand the combined Logic category contents back into its original categories.
  • Improved UI and color contrast for disabled blocks.
  • Added ability to pin help documents of the last selected block or command.
  • Added interface zoom control for the VEXcode desktop interface.
  • Fixed issue where dragging motor commands from the text toolbox with the Arm preset used a generic “motor” instead of the Arm motor.
  • Updated sensor behavior so calibration only occurs when configured.
