Hello everyone! I just wanted to share that VEXcode GO version 3.0.0 is now available. It can be downloaded here.
What’s New:
- Major VEXcode core updates for increased stability and to support future enhancements
- Updated sensor and variable monitoring system to allow easier monitoring of motors, sensors, and variable values
- Enhanced the core Blocks interface of VEXcode for increased compatibility with computing devices and to support future features.
- Updated sensor and variable monitoring system to allow easier monitoring of motors, sensors, and variable values.
- Introduced a feature that automatically updates all blocks using the old name to the new name when renaming devices in VEXcode.
- Added a feature that disables any blocks using a device instead of generating errors on run when the device is deleted in VEXcode.
- Enabled users to delete and rename broadcast events within a Blocks project.
- Introduced translation support for the Italian language.
- Fixed an issue where duplicate names between variables and broadcast event names were preventing projects from being run.
- Resolved an issue where invalid Drivetrain gear ratio settings were preventing a project from being run.
- Resolved an issue where the motors might spin unexpectedly when using some devices to control the VEX GO Brain.
One thing that I did want to highlight from this list is the change to the sensor and variable monitoring system. You can now select and drag blocks from the Toolbox to monitor!
For more information about monitoring sensors and variables, view this article.
