VEXcode IQ version 4.60.0 is now available. It can be downloaded here: VEXcode Install IQ - VEX Robotics
The VEX Library’s New Features in VEXcode IQ 4.60 shows off all the new features in this release.
- Redesigned Python and C++ toolboxes with collapsible sections, syntax highlighting, and category icons for easier text coding.
- Reorganized Blocks toolbox with clearer categories, subcategories, updated groupings, and active category highlighting so blocks are easier to find.
- Improved help documentation to use the VEXcode API site for IQ (2nd generation).
- Updated block color themes for better readability and accessibility.
- Added string blocks for working with text in Blocks projects.
- Split the Looks category into separate Console and Screen sections so print commands and screen controls are easier to locate.
- Combined math and comparison functions into a single, streamlined operator block.
- Brain Information now shows Console Serial Port status, and Print Console displays an overlay when the port isn’t connected.
- Added Bluetooth support for IQ (2nd generation) Brains in web and desktop apps.
- Added support for the new IQ (2nd generation) AI Vision Sensor.
- New projects now default to IQ (2nd generation).
- Refreshed app icons with brighter, higher-contrast colors for better visibility.
- Simplified generated code when printing variables and Boolean values.
- Resolved an issue where projects saved on Android tablets used incorrect file extensions.
- Resolved an issue where generated event-related code remained after event blocks were deleted.
- Resolved an issue where project downloads failed due to a timeout.
- Resolved an issue where the Feedback panel overlapped Tutorials.
- Resolved an issue where the play note block generated incorrect code for whole notes.
- Android minimum system requirement is Android 9.
- FireOS minimum system requirement is FireOS 7.0.
- Chromebook minimum system requirement is ChromeOS 100.
- iPadOS minimum system requirement is iPadOS 16.
