Getting Started with VEX Passport? Here’s How It Works:
To appear on the VEX Passport map and connect with educators around the world, you’ll need at least one VEX certification. Not certified yet? Start with a free Intro Course, it’s the first step to getting put on the map, literally.
Step 1: Open the Passport tab
Log into PD+ and select Passport from the left navigation menu.
Step 2: Update your profile
Click Edit Profile to add your display name, school, and a short bio. Your location details help place you on the map.
Step 3: Enable your permissions
Click Edit Permissions and turn on what you’d like to share including; your name, school, about me, and whether others can connect with you through the PLC.
Step 4: Explore the map
Search by country or city to find certified educators in your region, or filter by VEX platform to find educators using the same tools as you.
Step 5: Make a connection
If an educator has connections enabled, click Connect in PLC to send them a message directly in the community.
Learn how VEX Passport works
Read the full Insights article
Watch Jason McKenna’s keynote
We’re here if you have questions, drop them right here in the Passport category and we’ll get back to you! ![]()
